Frigidaire FGX831FS5 washer/dryer combo belt not moving
HIDEOUS-crotche
US
FGX831FS5
Frigidaire
Problem started when I noticed a burning smell coming from the unit. I narrowed it to the belt that was damaged. I replaced the belt and noticed that the motor pulley would spin but not the belt itself.
I next replaced the idler pulley but the issue still exists.
What could be causing the motor pulley to rotate but not the belt itself? Thank you.
Take the belt off completely, then run the motor by-itself and see if the motor runs.
It looks and sounds like your washer motor is bad.
Here's the washer motor for your model:
HIDEOUS-crotche
US
Thank you for the reply Jake.
I will take the belt off and see if the motor runs. It's tough to see in the video, but the motor pulley is spinning.
But the motor pulley does not look like its spinning fast enough.
Also turn the transmission pulley while the belt is off, to see if it turns freely both ways.
Yes I see now you have two problems.
1. The transmission is not turning the other way to spin the inner tub, so either you got something stuck/jammed in between the inner tub and outer tub keeping the inner tub from spinning, or the spin bearing has seized up, and seeing all that rust on the transmission, it's most likely the latter.
2. When the motor is running its way too loud and that indicates the motor bearing is bad too, and its only a matter of time that seizes up the motor shaft from turning too.
Here's the spin bearing for your model:
3204405 Spin Bearing
There is a video in the spin bearing part link that shows you how to remove the inner tub, so you can see if something is stuck/jammed in between the inner tub and outer tub, and also how to replace the spin bearing.
HIDEOUS-crotche
US
Thanks Jake.
I will try to replace the spin bearing.
For more evidence, I took off the agitator and notice lots of debris in the tub. I lifted up the tub cover (wasnt able to unhook the tabs in the back since it's stackable) and was able to rotate the tub/transmission pulley in both direction. Whenever I would change direction, it took some force.
Thanks again.
That issue seems to be the lower bearing housing assembly that's mounted on the bottom of the transmission. Seen this many times. Only solution is to replace the transmission.
Here's the transmission for your model:
Transmission Assy 134735700
