Frigidaire FPBM3077RFA microwave has no power
Joemah
Texas
FPBM3077RFA
Frigidaire
Have had microwave about 18 months without issue. It just decided to lose all power, no display or anything. Not aware of any power surges or anything at the house. I checked that the socket has power and is working correctly. Any ideas?
Any ideas?
Fuse, filter/fuse board, cavity thermal cut out, magnetron thermal cut out, pc board could do that.
LINK> Microwave fuse
LINK> Microwave filter ( where the fuse is )
The fuse should be checked first...
[video=youtube_share;NRb7-ATAq6M]https://youtu.be/NRb7-ATAq6M[/video]
Joemah
Texas
Thanks for the reply Jeff. I pulled the fuse(It visually looks good) and also pulled the door switches. Going to buy an ohm meter tomorrow to check the continuity.
Joemah
Texas
Checked the fuse and it was good. Checked all 3 switches and they were good. Checked power to the noise filter and coming out of it and it was good. Checked power to and from first cut out and it was good. Checked to and from second cutout and only the power to it was 120v. Other side was 0. Took out the cutout and checked for continuity and no good. Checked 1st one to verify I was doing it right and it showed continuity. So I should just need to replace that cutout, right? It shows to be part number 5304464094.
Joemah
Texas
Thanks for the info Jeff. I just got back into town. I connected the 2 wires together and plugged it back in. The vent fan immediately came on but no power to the display still. 😞
Any idea where/what to check next?
If the fuse and thermostats check ok, check for power to the board itself....power in but no go indicates a bad board.
