LongIslander
- FFU14F5HWG
- Frigidaire
- 6-10 years
Recently our freezer warm light has been blinking and staying on. I measured the temperature inside at around 20 degrees fahrenheit. When I took off the inside back panel there was a little ice around the defrost thermostat and the bottom/drain hole were filled with ice. I have since replaced the defrost thermostat and the temperature inside still only gets to around 20. I saw that the freezer evaporator fan motor was spinning. What should I possibly check next? Any help would be greatly appreciated.
