FIXED Frigidaire FTFB4000GS1 Won't Spin
rahoffman2
MI
FTFB4000GS1
Frigidaire
Washer was showing E43 error code (Control Board Communication problem).
I replaced the Control Board and it is still showing the same error and won't spin.
It will spin in diagnostic mode. :/
Can you help me with this?
Here's the tech. data sheet for your model: https://drive.google.com/open?id=1WxnOW1g4wG1pHEmpNzNTl85GQLwiKrZH
E43=Control Board Problem --->Replace Control Board.
Ok, I did some research on the E43 and a few other members replaced the control board and that didn't fix it.
It turned out to be the door latch/lock assembly that was the cause.
Here's how to test the door lock latch switch assembly: Remove the door lock assembly and measure the resistance of the PTC.
The PTC is the wax motor on the door lock assembly. You will need a multimeter to test that.
If it reads 1500 ohms, then its fine, and the problem would be the control board.
Here's the door latch/lock assembly for your model:
131763256 Door Lock/switch Assy
Video included in part link.
137005000 Control Board
rahoffman2
MI
Thanks Jake.
I will check that tonight.
BTW, I'm not sure what the "PTC" is, but I found page 48 & 49 of the manual helpful.
Rich
Ok Rich,
The PTC is the orange part sticking out of the door lock switch, yours may be another color like white if its not orange.:)
rahoffman2
MI
Switch checked bad.
Bought an OEM switch.
Replacement took 5 minutes.
Wife reports that 1st load washed and spun normally! YAY :)
Thank for your help Jake!
Excellent rahoffman2, glad to hear the new door switch fixed it.:)
