Frigidaire Gallery Ice Maker Troubleshooting FGUS2642LF0
JennyLiehr
Virginia Beach
FGUS2642LF0
Frigidaire
Hello! Looking for some help in troubleshooting an ice maker on a Frigidaire Gallery Model # FGUS2642LF0. Here are my troubleshooting notes/attempts:
1. Zero Ice has been made
2. Spring arm can be moved to off position but will not drop down all the way to the on position, it gets stuck half way.
3. Water is dispensing fine on the front of the fridge and water is getting into the ice maker itself.
4. Ice auger is functional when there is ice in the bucket.
5. We have defrosted the ice maker twice, once with a hair dryer and once without.
Any help is much appreciated!
Kindest regards,
Jenny
Corrected model number
Hi Jenny, Nothing pulls up for FGUS2462LF0.
Please check your model number again, I think you inverted the 6 and the 4 in your model number
This one does pull up as good--->FGUS2642LF0
Perfect thanks Jenny!
The problem is the ice maker itself, because that metal arm should come all the way down to make ice continually.
Here's the ice maker for your model you can order:
241798231 Ice Maker
When you click the ice maker part link you will see a Video of how to remove and replace it.
Ok Jenny, sounds good.
