Frigidaire Gallery Oven (1995) Won't Light
mgordonb
Michigan
Iv'e replaced the oven ignitor ($55) and tested the Gas Valve which tested good. I guess it's the Digital Control Panel (Clock, etc.) that's not sending power to the igniter and valve. That's $161 ! ! ! Anybody else have a newer Frigidaire oven that won't light but the ignitor is good?
-Mark
Update: It was indeed the eletronic control panel. It was not sending power to the ignitor/gas-valve system. Tip: you should be able to see the ignitor glowing orange through the vents in the bottom oven panel before the gas valve even tries to turn on. No need to take anything apart at first. No glow means either bad igniter or bad control panel.
Tools needed to remove ignitor (below bottom oven panel): Phillips, 1/4 socket set and driver.
