- LGUB2642LF4
- Frigidaire
- More than 10 years
Frigidaire Gallery Refrigerator LGUB2642LF4 - SY EF Error - Replaced Evaporator Fan and Control Board. Still not fixed.
Time Line up to SY EF Error.
- Replaced top ice maker due to ice tray cracked
- Every time top ice maker defrosted, water would run down inside back wall and run into freezer due to the drip gard being cracked
- Water line to bottom ice maker would freezer and I would have to steam the ice away.
- Replaced water filter due to slow water flow.
- Went in to diagnose mode not knowing what I was doing and just hit buttons. When I could not exit I pushed the freezer down errow until the display went out. Then after some time the display blink and everything looked normal.
- Next day SY EF showed up on display.
- Replaced Evaporator Fan - New fan only spins for a second and then stops. The fan will repeat this until the display shows SY EF. Check all wires from fan to board and everything showed good continuity.
- Did not know if the new fan was bad or not so I ordered a control board and another fax.
- Still having the same problem. The only way I can get the fan to run is the set my multimeter to Hz and put one end on the yellow wire and the blue wire on the control board.
If any one has any ideas of the issue I am having please let me know.
