Frigidaire Gallery Series Range LGEF3045KFJ oven not heating properly
dja4260
SC
LGEF3045KFJ
Frigidaire
Hello! This forum comes highly recommended so here I am.
Frigidaire Gallery Series LGEF3045KFJ. The oven heats up about 1-2 degrees every 5 minutes on bake. Obviously, I can't get it to operational temperature.
Thus far I've checked the following:
Voltage at the wall, ~125v @ each leg
Voltage on the back of the unit ~125v @ each leg,
Voltage on the back of the unit, combined leg ~240v
Temperature probe- 1106 OHMS
Bake element- 14.6 OHMS
No visible burns or damage to control board.
I'm perplexed on what the issue is...
Please advise!
Got it! Then its likely the clock oven control board has gone bad.
Here's the clock oven control board for your model:
Frigidaire 5304495520 Kit
Since you have a multimeter, on the back of your clock oven control board: put one meter probe on L2 OUT and the other meter probe on BRL when you have the broil cycle turned ON, you should get 240 volts.
Then put one meter probe on L2 OUT and the other meter probe on BA when you have the bake cycle turned ON, you should get 240 volts.
If you don't get 240 volts on either bake or broil or both, order the clock oven control board kit I posted the link to above.
dja4260
SC
I tried that and didn't get voltage. I'm going to purchase that board from Amazon and hope for the best.
Thank you for your help!
I wouldn't order it from amazon, too many parts from amazon are either aftermarket or cheap knockoffs from China with little or no warranty.
Many people have got burned getting parts from them.
Here's one example:
All parts from AppliancePartsPros and RepairClinic are ALL OEM parts. ALSO--->All parts you order from them come with a 365 warranty.:)
