- 970L97522F0
- Sears Kenmore
- 1-5 years
I have a faulty washer selector switch on my Kenmore stacker Model 970L97522F0. It is a 9 cycle washer with Selector Switch 137493400
I also have a spare non-functioning Frigidaire stacker Model FFLE39C1QW0. It is an 8 cycle washer with Selector Switch 137493300
When I swapped the 8 cycle switch from the Frigidaire into the Kenmore the machine works. The problem is that the cycles don't match the panel on the machine (selector has 8 cycles but panel has 9 cycles). If I swap the front panel from the Frigidaire over (now the panel has 8 cycles and the switch has 8 cycles) will that be the final solution or do I need to change some other part in the machine as well? I don't know if the washer selector switch controls the actual wash cycles or is that a different part of the machine that does it.
