G
Guest
Guest
- FGMV174KFB
- Frigidaire
- 6-10 years
So I watched a lot of You Tube videos First thing I did was test door switches all good continuity. Next the thermostat behind control panel. no conductivity. replaced 5304502765 now the blower fans run soon as I plug the unit in and fan controls can change speed just no off. Microwave still runs different tone and no heat. Next tested magnetron passed tested capacitor and it passed. tested diode and needed to replace it. the new one passes. microwave still has blower motors on micro turns on different tone and no heat. tested thermostat on the top under the plastic with positive conductivity. Also ceramic fuse is good.
I'm about to just buy new but after spending 80 bucks on diodes and fuses I would like to know what I missed could the transformer be bad. I did test it and seemed to be within spec. Thanks
