Cmerrill
- FGMV176NTF
- Frigidaire
- 1-5 years
So it happened twice the past week if I opened the door with the microwave running it blew a breaker. Now it will blow anytime you hit start and try to use it.
Is it the center one?It's not.
That's called the monitor switch, sometimes called the "dead man" switch. It's purpose is to keep the microwave from running with the door open by shorting L1 and Neutral together. When you open the door L1 to the monitor switch is interrupted by the primary switch. The primary switch needs to open just ahead of the monitor switch. That's the reason you need to test the switches by opening and closing the door. The bracket that holds the switches could be worn out or out of adjustment. There's very little adjustment but you can loosen the screws and push the bracket in place the tighten the screws.It was the middle one.
It's bad. Replace it.it’s in the constant down position.
That’s the one I just bought and replaced already from the start of the thread.It's bad. Replace it.
Did you get it from Appliance Parts Pro? Ask them. I'm sure they will replace it for you.
I did. Do you know what the other two switches are? This one is the one in the middle. The one you can activate without taking the microwave apart. I’m assuming the two are different part numbers? Is that right?Did you get it from Appliance Parts Pro? Ask them. I'm sure they will replace it for you.
