Frigidaire Microwave FGMV176NTF trips breaker when power turned on
dwmw
Cumberland, RI
FGMV176NTF
Frigidaire
3 year old microwave trips breaker when power turned on. Had an appliance guy check it out. He replaced 3 switches and fuse. Ran for a couple of days and then same problem. Fan doesn't trip breaker, opening door doesn't trip breaker, just when pressing start to heat contents. Appliance guy returning later this week - any ideas and what should I ask him ? Any help appreciated, thanks
Probably a bad control board Try it with the wires disconnected from the primary side of the transformer. That would eliminate all the high side components as being the problem.
