Frigidaire Microwave Isn't Heating
Somerset John
California
FMT148GPB2
Frigidaire
I have a Frigidaire Gallery Professional Series FMT148GPB2 Microwave. Everything on it works except for the heat. It lights up, buttons beep, carousel rotates ... just no heat.
I watched an apartment maintenance person once repair a microwave. He removed a few screws, removed the front panel, pulled out something that looked like a circuitboard, and popped in a new one. Two minutes work, max.
I'm hoping that such a repair might be as easy on my unit? Maybe even just a fuse? (I know, wishful thinking.)
Also, if someone is able to post a miracle answer for me, perhaps you can suggest where I ought to buy whatever part I need.
Somerset John
California
Thanks, Jeff.
I'll take your word for it and assume it's not the fuse, since everything else besides the heat is working.
I guess the real question is ... where do I find a tutorial or some instruction to fix this myself?
-JOHN
A way of testing to see if the microwave is creating high voltage or not...
http://www.applianceaid.com/micro7.html
First thing is to find out if the microwave is creating high voltage...if it is and no cooking = new mag time...if it is not then we look else where.
I don't know of anything model# specific.
This here may help.
