Frigidaire Microwave PLMV169DCD loose door hinge
mbest
Hilo, HI
PLMV169DCD
Frigidaire
When the door is open, the hinge is loose so that the door sags and can move up and down. There doesn't seem to be a problem when the door is closed, though, so the microwave continues to work otherwise.
