FIXED Frigidaire Microwave Stopped Heating
handsometoo
upstate NY
PLMB186KKC
Frigidaire
Hey all! Hi Jake,
All seems to be working, count-down, turn-table, keypad etc. the only clue (besides no heat) is its louder while running...
Can you help me?
handsometoo
upstate NY
Thanks for the quick get-back...
Just checked the door switches (there's 3) the middle switch has continuity all the time, door opened or closed. Could this be the issue?
handsometoo
upstate NY
Forget the magnetron, I'll go first with the diode.
What is a replacement part number for the HV diode? or the values needed to match the orginial? Seems there are different part numbers depending on where you look. Then there's the price variations....
Sears wants $70., others $35.-$40., seems a bit much for a $3.-$10. item.
Any suggestions?
handsometoo
upstate NY
Hey Jeff,
Thanks for the great advice, installed a new magnatron and all is fine.
My Q: Is it nesscessary to also install a new HV Diode along with this magnatron?
Thanks in advance...
Necessary, no....we often do as one can effect the other.....but if all works well now I'd leave it alone.
