Frigidaire microwave wont heat
acrook
Coos Bay , OR
fmv145bc
Frigidaire
I have a frigidaire over the range microwave. A couple of months ago it started arching (shooting a small lightning bolt) if there was not a substantial amount of food in the oven. now it arcs and wont heat at all. Everything seams to be working it even sounds like it is heating but it is not.
I found FMV145BC1
Burnt wave guide cover, burnt stir blade, burnt magnetron end...all are common for arcing inside the microwave.
Magnetron and hv diode are common for not cooking but still sounds like they are working.
http://www.applianceaid.com/micro7.html
