Bunky
- FGMC2765KBA
- Frigidaire
- Less than 1 year
The oven worked fine. We did a 3 hour self clean. Now the oven does not get over 220 degrees. When preheat is set, the beep indicator goes off indicating it has reached 350. When you hit bake, it then shows the actual temp at only 220 - 229 degrees. I left it on for an hour and it peaked at 229. I believe it is only at 220 or so as it is not really very hot, and the chicken only got a little done (darn it). Any ideas? Temp sensor?
UPDATE: after an hour and a half, it reached 305 degrees....
Thanks, Mark
Thanks, Mark
