Frigidaire Professional Gallery FRS26ZSEB1. Ice shooting out dispenser by itself. When you open the door it stops, close the door and it starts again.
Surfside
Surfside
FRS26ZSEB1
Frigidaire
Frigidaire Professional Gallery FRS26ZSE. Ice shooting out of dispenser by itself. When you open the door it stops, close the door and it starts again. Any suggestions on where to start. I was unplugged the wire harness and cannot use the door water or ice.
Added complete model number
Your missing 2 digits after the "E" in your model number, read it from the model number tag, which should be located in the refrigerator section on the upper walls or ceiling.
Surfside
Surfside
FRS26ZSEB1
If you switch it to water does the water from the water dispenser keep flowing out non-stop till you open the door too?
Here's your parts diagram:
(click to enlarge)
Here's the #7 microswitch, that activates the ice and water and if that is bad or sticking it would cause this issue for BOTH ice and water to keep coming out non-stop.
Switch-Dispenser Micro 5303917595
You would need a multimeter to ohm test it for continuity when the button on the micro switch is pushed in. Should read 0-1 ohm. Unplug or turn the breaker off to your refrigerator first.
Remove the module cover#14 then remove the screws#26, the use a putty knife to remove the trim, its all 1 piece, it has double-sided tape on it, don't worry about that, it will go back on fine, when you re-install it.
If the #7 switch is good, Then its the ice dispenser switch that's bad, the diagram does not say which is the ice dispenser switch, its either #38A or 38B, but test them both and see which one is bad or sticking.
Here's #38A switch:
Micro Switch 218479900
Here's #38B switch:
Switch, Dispenser 218480000
Surfside
Surfside
We appreciate the quick response. I will purchase a OEM meter, and let you know how it works out.
Ok, sounds good.
