Frigidaire Professional Series Microwave No Power
sjeffers01
Rancho Cordova, CA
PLMV169DCD
Frigidaire
My microwave was working fine the last time I used it. When I when I went to use the next time, the panel had no lights or power. I checked my house fuse and tested the plug in outlet and they were fine. I looked at the parts list and found a thermal fuse. Before I spend $40+ I would like to know if the fuse is the problem or if there are any other fuses I should check.
For sure check the fuses and thermostats. Fuses are more common.
They can and should be checked for continuity before ordering anything....open or no continuity is bad, has continuity and the item is still ok.
00857650.jpg Thermal cut-out fuse
00720314.jpg Line fuse and monitor switch kit
