Frigidaire Range FED355ASD Large rear burner does not work and the front large one cannot regulate the heat setting
phmichel
FED355ASD
Frigidaire
Our drop-in Frigidaire range is showing it's age. 19 yrs old. The large rear burner does not work and the front large one cannot regulate the heat setting (goes to full-on High after about 5 mins no matter what the dial is set at). Would like to replace all burners and whatever controls are needed to fix the heat regulation issue. I would really appreciate some guidance as to how to proceed. I am a former mechanic and and capable of a DIY project like this (I've replaced burners before...). Thanks for you help!
Check the element that doesn't work for continuity with a meter. Also check the receptacle the element plugs into. Replace the surface unit switch for the one that stays on high.
