- PGLEF387AS2
- Frigidaire
- More than 10 years
The stove seems to be possessed. From time to time I can hear it beeps, and sometimes when I was in the kitchen when it beeps, it is like someone pressing the button. It was so bad for a few times I catch it actually turned on the oven!! So I engaged child lock. But still, one time I withness the child lock get disabled by itself...
I have tried to clean the glass surface, so clean it looks like new, but that doesn't help much.
Eventually, I just removed the touch controller board and leave it with F1 display the whole time...
I have tried to look for a replacement to see if is the controller has gone bad, but I couldn't find any. In fact, the whole module, including the oven control seems to be discontinued a while ago.
That's until I found this forum!
Does anyone have some tips on what might have actually gone wrong? The model I have is hard to find info, but I found a similar model (PGLEF387CS4) which looks like it uses the same controller.
Oh, I did try to use the oven (with the touch controller connected), it is just bloody annoying to the point I give up using it. It is difficult to 'press' any button and even when the oven is on, the 'random pressed' often result 'cancel' being pressed and turning off the oven. I wish I can just replace the panel and controller (which uses actual buttons and not touch sensors)...
