FIXED Frigidaire Refrigerator FFHS2611PFEA Ice Maker not working
GaryJF
FFHS2611PFEA
Frigidaire
I have a 5 year old Frigidaire Model FFHS2611PFEA, we were out of town for several weeks so I turned off the house water; when we returned and the water was back on the Ice maker isn't working it doesn't appear to be getting water the water in the door works fine.
What could be the problem? Is there a separate filter or valve for the Ice maker?
paulhl
Flemington NJ
Your inlet tube is frozen. When you shut off the water without disabling the ice maker it continued to cycle with little water coming in and froze. Hair dryer time to thaw it
GaryJF
Do I remove the rear [late behind the Ice Maker to access the line?
Yes, Paul is correct.
Here's the ice maker fill tube for your model below, when you click the link to it you will see a video of how to remove it to clear the ice clog out and replace it.
GaryJF
I did that and it is clear, but no water is coming up the line; I did fill the ice maker manually with water and nothing happened. I am starting to think it is the "on-Off" switch as it doesn't cycle.
Gary
Ok Gary, I don't see a OFF/ON switch on your ice maker.
It sounds like the ice maker is not sending 120 volts to the water inlet valve for it to fill with water--->If you want to verify that, pull the freezer out from the wall, then locate the water inlet valve, where your water supply line hooks up to.
You'll need a multimeter to see if your getting 120 volts to the ice maker GREEN SOLENOID side of the water inlet valve. The GREEN SOLENOID is for the ice maker water. Just remove the plastic electrical connector that goes to it, then put your meter leads in each one and then cycle the ice maker(turn the gear 1/4 turn clockwise then let it rotate on its own) and watch your meter for 120 volts towards the end of the cycle. If you don't get 120 volts, then your ice maker is the culprit.
Look at the photo of it below, I see no OFF/ON switch on the side of it.
241798231 Ice Maker
Excellent Gary, glad to hear the new ice maker fixed it.(y)
