corvairbob
- FFSS2614QE0
- Frigidaire
- 1-5 years
i have the FFSS2614QE0 model Frigidaire side by side unit and every now and then when i get ice i get crushed ice, the selector is set for cubes. i open the door and push the ice unit back in about 1/4" and then i start getting cubes again.
so is there a fix for this issue? or do i have to build some kind of barrier to hold the ice unit back against the back of the auger motor? i have taken the unit out to see if anything is back behind it causing this but i have never found anything, no have i ever hear ice drop as i pulled the unit out to investigate it. i guess i can cut slots in the sides and get a pc of flat iron and use that to hold the ice maker assembly back up against the motor area but maybe there is another way. thanks
