Frigidaire Refrigerator FGHS2655PF2 water dispenser will not shut off
stb
dallas tx
FGHS2655PF2
Frigidaire
I have a Frigidaire refrigerator, Model FGHS2655PF2 , Gallery model. Wiring diagram 242288401.
It has a in door water-ice dispenser.
The other day it suddenly started dispensing water with no one pressing the lever.
Even with the operator panel in the ICE mode , and the dispenser arm not activated, The water Solenoid valve for the door dispenser is now constantly activated.
I have replaced the Control module (242270101) and the User Interface panel (242058233).
This has not fixed the problem..
As soon as I plug in the electrical connection for the door dispenser water solenoid , it is activated and water flows.
If I unplug the water solenoid control line water shuts off , so the valve is functioning OK.
IS there a relay that activates the water solenoid somewhere that has failed?
Thanks for any help.
Its the main control board that's bad and causing this problem.
Another member had this same problem, the main control board fixed it:
And it was the main control board that was the cause.
Yours takes a different main control board part number.
Here's the main control board for your model you can order:
242115254 Board-Main Power
You know where its located?
When you order parts from AppliancePartsPros or RepairClinic, you a have 365 day warranty on ALL parts!
Yes, that is correct, did you already replace it? Or it hasn't come in yet?
