FIXED Frigidaire Refrigerator FGHS2655PF5A Water dispenser turns on without being activated
TonyAnon
Largo
FGHS2655PF5A
Frigidaire
Water dispenser turn on intermittently for roughly 4 seconds. I place an empty cup there at night and by morning it's full. What part shall I replace? Thank you.
Here's the wiring diagram for your model: https://ecommcdnprod.azureedge.net/...roduct_support/FPH/FPHS2699PF4A/A01461101.pdf
When this problem happens its usually either the dispenser module or main control board. Lock the dispenser control and see if it still intermittently shoots water out.
Here's the dispenser module for your model:
242270101 Module
TonyAnon
Largo
Thanks for your reply. Unfortunately I've already swapped out both parts you suggest and the problem continued. Is there another option? Thank you.
TonyAnon
Largo
I put the dispenser module indictor on "Ice" and locked It. The dispenser still dispenses water intermittently. Thank you.
Ok, pull the refrigerator out from the wall, then remove the lower rear access panel and locate the water inlet valve and remove the electrical connector to the YELLOW solenoid and leave it disconnected and see if it still randomly shots out water from the water dispenser.
242252702 Water Valve
TonyAnon
Largo
I've disconnected the yellow connector. I'll report back in a couple of hours. Thank you.
Good! We found the problem, its the water inlet valve that's causing it, because no electrically is going to it, and the diaphragm inside that valve is opening intermittently which equals failing.
Excellent Tony, glad to hear the new water inlet valve fixed it.(y)
