Frigidaire Refrigerator FPRH19D7LF Light at top doesn’t go out when door closes
juice93
Windsor ON canada
FPRH19D7LF
Frigidaire
Light at top doesn’t go out when door closes and heats up tremendously melting part of the housing. Pressing the the door switch does not turn light off. Do I need a new control board or switch? I have a control board from the matching freezer. What are the chances I could put that in the fridge?
juice93
Windsor ON canada
New switch and nothing changed. Old switch registered 0.0-0.2ohms. Putting a bulb in for just seconds and it heats up tremendously.
Can I put a control board in from the matching freezer?
This was the switch at rest?...if yes, that is normal.
Should have showed infinity ohms with the switch pressed.
If the model#'s an board #'s are the same, should be able to no problem.
jeff sr.
