Gryphon
- FRS24ZSGB0
- Frigidaire
- More than 10 years
Frigidaire Gallery Professional FRS24ZSGB0 icemaker will not fill with water and make cubes. It was working fine before vacation. When returned, no ice and water fill tube was frozen. Defrosted it and no water so changed water inlet valve . When we manually recycle icemaker and the freezer has been on long enough the water inlet valve attempts to allow water into hose leading to the fill tube (solenoid sounds like it's trying to engage). Figured maybe icemaker not sending proper voltage to new water inlet valve to put in new icemaker. After waiting again for freezer to reach 0 degrees, again manually cycled icemaker and solenoid again seemed to engage to try to let water flow thru tube up to the icemaker fill tube but only a trickle, By the way, the water at the door (other solenoid on the dual inlet valve) works fine saying at least water is getting to the dual water inlet valve. Also, looks like there is an assembly buried in the wiring near the dual water inlet valve and some of the schematics show a two diode assembly but can't find anything about this and our problem.
Do you know what might be the problem as it's a big mystery to us.
Gary and Kathy
Gary and Kathy
