Beernut
- FRS6LR5EM6
- Frigidaire
- More than 10 years
The icemaker isn’t working. I searched extensively for repair info before coming upon this website. I have replaced the door switch, and the water valve. I replaced the icemaker also, but after seeing no change after replacing the water valve, returned it for a refund. I found a previous post (Fireman Jim, 1/22/21) with a similar issue. There is 120V at the water valve when I manually turn the cog and initiate the icemaker to take over and continue the cycle. When reconnected, I discovered two things:
1) The water connection for the IM was not secure and spewed water. I fixed that.
2) The water dispenser on the door spewed water when the icemaker engaged it’s fill function. I did not fix that, but wish to.
During my efforts to alleviate the nonfunctioning IM, I removed the cover from the face of the IM and clicked the switches to test them. All clicked when pushed. I did not perform any tests with a multi tester. Hopefully, I put the cog on the paddle stem in the correct orientation. Unfortunately, I didn’t note this before removing it from the stem.
I hope someone here can assist me in fixing my refrigerator.
Thank you.
-Rick
Thank you.
-Rick
