You are correct, my bad, I did not see that listed the first time, this is a newer style I have not come across as of yet with both.
Here it is:
Frigidaire 5303918776 Thermistor (AP6041625) - AppliancePartsPros.com
THERMISTOR 5303918776 / AP6041625 made by Frigidaireclick.linksynergy.com
Here's the tech data sheet: https://ecommcdnprod.azureedge.net/...roduct_support/DGH/DGHF2360PFBA/A06589001.pdf
In SYSTEM DIAGNOSTIC MODE do test 39--->Freezer Evaporator Thermistor
Thank you!
K so I did the following tests:
- test #2 (frozen defrost heater). I turned it on and waited like it said and it did not increase temperature. it kept flashing 95 deg F
- test #29 (FF thermistor). it showed 48 deg F and my thermometer confirmed it but the fridge is set to 38 deg F
- test #30 (FZ thermistor) it showed 10 deg F and my thermometer confirmed it but the freezer was set to 2 deg F.
- test #39 (freezer evaporator thermistor). it shows 95 deg F.
