Frigidaire Refrigerator LFSS2612TF2 both sides not cooling H1 code...
ballyhooo
LFSS2612TF2
Frigidaire
Ongoing problem last few days so emptied both sides and pulled back panels. Evaporator coils were iced up especially at the top section. I have been reading similar issues on this board and followed some advice to check the evap heater which ohm tested good. Next I checked the evap thermostat which failed the ohm test. Check the evap fan motor which tested good. So I am going with replacing the evap thermostat and hope that solves the issue! Any other suggestions while it is torn apart? Many thanks!
Did you Ohm the defrost thermostat for continuity(0 ohms) WHILE ITS FROSTY while the refrigerator was unplugged?
Here's the defrost thermostat for your model:
5303918214 Defrost Thermostat
There is a video when you click the part link to the defrost thermostat, it shows where its at.
Watch this video: Defrost Thermostat Ohm Testing Video If it's frosty you don't need to remove it and put it in ice water to ohm test it.
If it has no quick disconnect, you will have to cut the wires and splice back the insulation a little, don't cut to close to the defrost thermostat itself as you will need 2 wire nuts to connect the spliced wires back together.
ballyhooo
New defrost thermostat worked for 1 week and now back to same problem...evap coils iced up and H1 code on freezer side. Would it be worthwhile to run the diagnosis mode? How is that done? Thanks in advance!
Ohm test that new defrost thermostat you got and see if it passes or fails.
Look under SPECIAL MODES:
MANUAL DEFROST--->Press and hold FRZ UP; then press FF DOWN key 5 times within 5 sec. Input is recognized when FRZ UP is released. Same to deactivate.
Then LOOK under SERVICE MODE.
  • 808662202 (3).pdf
ballyhooo
Jake thanks for the data sheet. All tests were normal. Ohm checked the defrost thermostat and it is working. It ran for another 4 days then froze up once again. The H1 code for freezer is flashing but temp in freezer is showing 0 on thermometer and 39 in refrig side. Could it be the control panel? About the only part left...Thanks!
Yes, Here's the part you need:
ballyhooo
Dear Jake...part came in and I replaced the control panel today. It is running and seems to be cooling so far but when I turned power back on I have either a PO or OP code flashing on both sides. The only thing close to that on the data sheet is open thermistor. Hate to keep bothering you but...any suggestions? Very much appreciated!
Take a photo of it and upload it here please.
ballyhooo
O in both then P in both.
That's not right, was it doing that before you replaced the electronic control board?
Did you order the electronic control board from my link to it in post #7 at AppliancePartsPros?
ballyhooo
Jake, no it never did this before. No I got the part at GQ Parts.com it was considerably cheaper, however it is the same Electrolux part. I read online that the P and O means power outage and you clear it by pressing the same "alarm reset" button. But it will not clear it...defective board? I already contacted them but have not received an answer yet! Also the evaporator coils are still FROSTING up as before!
Yes, that board is defective.
Your tech. data sheet does not even mention PO on yours, Power Outage is mainly the Whirlpool refrigerators that do that.
Order the board from my link to it in post #7 and it should work perfect.
Ok, sounds good.
