BackEastDon
- LGUB2642LF2
- Frigidaire
- 6-10 years
I have a Frigidaire Gallery with the evaporator fan error code. Quick web search, order both the control board and fan. Replaced both. Plug unit in, compressor and condenser fan turns on, evaporator fan spins for a second then nada. Fan continues to spin for a second every 30-45 seconds but compressor doesn't turn on.
A bit more searching and I find the service manual online along with the diagnostic mode. In both low and hi, the fan does the exact same thing. Put the old fan back in, same thing. Put the old control board back in, same thing. Do a pin to pin test from the plug to the control board testing continuity of the wiring. That all tests good. Got 12 volts, both old and new boards.
If I leave the fridge plugged in for about 10 minutes or so and cycle the unit on and off a couple times, the compressor and condenser fan will turn on and continue to run and the evaporator fan will do its spin for a second at a time thing. Coil is getting cold but unit displays the evaporator fan error.
I'm a former electronic repair tech and owned my own repair shop for a number of years. So I remember all too well having these kinds of days every so often. Anyone have any insights they can share cause I am kind of stumped.
