Frigidaire Refrigerator PLHS39EESS3 Display on OF
DannyinCanada
Ontario
PLHS39EESS3
Frigidaire
Experienced a power outage on Tuesday. The main circuit was switched off and when the power came back on the temperature control on my PLHS39EESS3 was at OF.
I tried to hold down the power buttons and also unplugged and replugged the fridge.
Is there anything I can do to fix it?
It sounds like the control board has gone out if you can't change the the numbers on it and its not responding.
This is the part you need below, but Its No Longer Available:
5303918340 Dual Digit Control
DannyinCanada
Ontario
Hi Jake, the fridge is also not working. It’s not cooling, is that also the problem? Is there a fix without having to call a technician.
Yes, the power outage possibly caused a power surge or power spike when the power came back on and blow out the control board, so the compressor and fans can't work now if the control is not responding.
Only replacing that control board, but its been discontinued by the factory.
Not that I'm aware of.
