bedfordave
- FFLG3911QW1
- Frigidaire
- 1-5 years
Age unknown but the building the unit is in is ~6yrs old.
This is part of a stacked Frigidaire Laundry Center washer/dryer combo -- dryer seems to be fine.
The washer has been randomly stopping, initially beeping 3 times. It was then beeping varying amounts at random times over the course of days while not in use, and took us forever to figure out the washer was the source of the beeps.
I have also noticed that there is not always a beep when the cycle selection knob is turned. I cannot find a pattern.
Eventually after doing a full control reset, we can usually get it to operate more or less normally (I cannot tell if there is any confirmation that a reset has been performed, but I have followed the below instructions). However, at the end of a cycle you can hear plenty of water in the bottom if you move the drum (water is not typically visible).
I have tried entering diagnostic mode according to the tech data sheet (https://drive.google.com/open?id=11H7BbxLLIKfoAt95MMXEZl9wfdoWUc3y) but I never receive the one long beep that the instructions say indicates that diagnostic mode has been entered.
Any troubleshooting advice or suggestions would be very welcome. Thank you for your time!
