ewanspeirs
- FFU1764DW4
- Frigidaire
- 6-10 years
Hi
I have an old stand up freezer, model # FFU1764DW4 frost free commercial 20ft - that is not cooling.
Condenser coils are in the walls, the walls do not get warm when the freezer is turned on
The evaporator fans works
The thermostat / internal off switch works, at least the off switch part does there is a solid "click" sound when turned to the off position
Door seals are fine
There is no ice build up the evaporator coils inside the unit
The compress unit at the rear of the freezer heats up and vibrates when the power is on
No obvious signs of leakage etc. from the compressor
Any suggestions on what else i can check to figure out the problem would be very welcome.
ewan
Door seals are fine
ewan
