Frigidaire Washer/Dryer Combo Model FFLE3900UW0 multiple error codes
J-stcyr
NY
FFLE3900UW0
Frigidaire
As stated in the title, my Frigidaire laundry center is giving multiple error codes. The issue first started with the dryer not running properly, light would blink and dryer would not start. At this time I didnt know about diagnostic mode and getting error codes. I checked the dryer vent for blockages, of which there were non. A quick google search led me to believe a thermal fuse blew, I had to remove the dryer tub from the unit to reach the fuse, once I reached the fuse a continuity test showed the fuse was still functioning. Taking apart the unit I found diagnostic mode literature and put the unit back together to run codes.
Reassembled the unit no longer had issues running the dryer, everything was in working condition. A few days later the washer unit started to give me issues, diagnostic mode was giving me E-5-3 error which is associated with a problem with a switch on the motor, here is where I start to lose the trail. Running the machine through the each diagnostic test the issue seemed to fix itself and there was no longer an error code. I was able to do one load of clothes before the washer gave up on me again, this time giving a E-15-3 error of which there was no corresponding code in my pamphlet and cant seem to find information online to what this code means. Any insight is appreciated, Thanks.
Hi,'
Sounds like a malfunctioning main control board problem to me.
There is a video in this part link for the main board location:
J-stcyr
NY
Thanks Jake, I suspected the same so you confirmed for me. Cheers!
Glad to help!
