Frigidaire Washer GLGF2940ES0 No final spin
Rrwasher
GLGF2940ES0
Frigidaire
I have a Frigidaire GLGF2940ES0 that will not final spin, I ,now this has been discussed before but my situation may be a little different. I live off grid and power comes from a 3000 watt inverter. I have bypassed the inverter and run directly from a 6000 watt generator. I have changed the door switch the control board and even the pressure switch, it seems to spin properly all the way to high speed, when it starts the high cycle the door switch clicks and all lights shut off then comes back on. When it comes back on it appears it is trying to restart the previous cycle. On drain and spin it seems to work properly. Any help would be appreciated! Thanks
