FIXED Frontload Kenmore Washer won't fill with water
laundrylady
United States
Help! I have a Kenmore frontload washer that will not fill with water. I get the FH code. I have replaced the duet water inlet valve and the drain pump. I have checked all the hoses and have looked for any fray wiring. I have ran the diagnostic test and all systems work except C:01, filling with water.
If I blow air into the pressure switch I hear two clicks. If I blow air into the flowmeter, I hear it spin. Suggestions??? Advice, please.
laundrylady
United States
Sorry, the model number is 110.42924200 It's a Kenmore HE3t. My fill hoses are the regular type. I did removed them and clean out the gunk. I tested the Pressure Switch with an multimeter. Contacts 21 to 22 (Empty) gave me a reading of .03. Contacts 11 to 14 (Suds), 21 to 24 (Level 1), and 21 to 26 (Overflow) stayed at 1 ohms.
Check the wires and connections between the fill valve and the VCH7 connector on the CCU. Measure the voltage at the fill valve when the machine should be filling. If it's not 120 VAC replace the CCU
Main Control Board 285924 Order now for same day shipping. 365 day return policy. RepairClinic.com
