Frozen water line and water filter
vsteo
Maryland
EI23BC56IS6
Electrolux
My water line and water filter keep freezing. Once I defrost them everything works perfectly but within 12 hours it is frozen again. I tried increasing the temp of my freezer to 4 degrees and my fridge to 38 degrees but that did not work. The water filter was recently changed. Please help. Thank you.
Nothing else is freezing in your refrigerator section?
You can buy a inexpensive refrigerator thermometer, Get the liquid or digital type thermometer like the one here I use: Taylor Digital Refrigerator and Freezer Thermometer - Walmart.com
Then leave it on the bottom shelf for awhile and tell me the temperature of your refrigerator.
vsteo
Maryland
The programmed temp is set to 36 degrees. The internal temp is about 36 but the temp in the vege drawer next to the water line is 32 degrees. I tried increasing the temp to 38 degrees but that was too warm for the food. The ice maker will not produce ice when the water line is frozen. As soon as I manually defrost the line the water and icemaker work fine until the line freezes again.
Thats very odd, you may need to contact Electrolux to have a tech. come out to see why this is happening: http://www.electroluxappliances.com/Owner-Support/Contact-Us/
The Electrolux tech. can call the factory support line from your house to see if they have received other reports of this happening and they may have a kit the tech. can order that will fix this issue.
