FRS26DR7DS Frigidaire refrigerator dispenses water on its own every 10 mins. Turning lock on does not stop this. Also ice maker stopped producing ice
steve_w
Clinton, MI
FRS26DR7DS3
Frigidaire
Frigidaire refrigerator dispenses water on its own every 10 mins. Turning lock on does not stop this. Also ice maker stopped producing ice a while ago. No visible ice build up on freezer. Frig and freezer operating normally otherwise
Hi Steve,
Here's the wiring diagram: https://ecommcdnprod.azureedge.net/...t_support/GLRS267ZD/glrs267zdw3/240389618.pdf
We need to do process of elimination to find the cause of that water coming out every 10 minutes.
Here's the parts diagram:
#24 is your water dispenser actuator, disconnect it.
#38A is the water dispenser switch, disconnect at least one wire from it.
If water still comes out every 10 minutes after you disconnected #24 and #38A--->#38C is the dispenser control board, remove the ribbon cable from where it connects to the power control board, which is #38.
Per this video:
Let us know what happens.
