FRSS22623ASC Frigidaire Refrigerator - Freezer temp normal, refrigerator below freezing temps
Bimmer-E36
Lees Summit
FRSS2623ASC
Frigidaire
Less than 1 year
New Frigidaire side-by-side freezer/fridge FRSS2623ASC, Serial Number 4A24404649, Manufactured 11/2022. The freezer temp is consistently 0 degrees on 'Recommended' setting. The fridge side holds between 0 degrees and 20 degrees depending on the setting. It's currently set on 'Cold' and ranges between 17 and 20 degrees. On the 'Coldest' setting it gets down to 0 degrees. Any help diagnosing would be greatly appreciated!
It would either be a bad temperature sensor(aka thermistor) in your refrigerator section or bad control board. But since its under warranty don't work on it yourself or Frigidaire could void your warranty.
You can contact Frigidaire support at 1-800-374-4432 and they will locate a Frigidaire tech near you to do the warranty work for free.
