FIXED FRT18TRCW3 Frigidaire garage fridge not working
maverickfhs
Earth
FRT18TRCW3
Frigidaire
So we have this FRT18TRCW3 Frigidaire garage fridge, where because of cold weather didn't realize but just checked and seems like compressor is not coming on.
Both fridge and freezer are showing temperature in early 40s, because of cold temps in the garage.
Could it be a relay or something else? Where should I start? Thank you :)
maverickfhs
Earth
Double checked and it seems like temp control in fridge area was messed up and hence nothing was coming on, for now good.
Mods consider this as solved or please remove it. Thank you :)
What do you mean by messed up? How did you fix it?
Here's our main thread on garage refrigerators:
maverickfhs
Earth
Thank you Jake. Now reading about it, outside temp is the reason for freezer not being at nominal temps.
Changed the dial a bit and compressor kicked in last night and I thought somehow dial control was moved by someone?
By major contributor is colder temp outside in the garage, in case someone else is looking:
Got it! Thanks.(y)
