FTFB4000FS1 Frigidaire Front Loading Washer Flashing Light
grisghost
Northern Virginia
FTFB4000FS1
Frigidaire
This started off with an issue where the control panel lights came on by themselves. From what I gathered on the web, it appears the control board has probably shuffled off its mortal coil, but the washer functions as expected. We usually leave the washer unplugged when we are not using it to avoid the light flashing issue.
Today when we started to use the washer, the Door Lock, Wash, Rinse, Final Spin, and Control lights started flashing in unison and the washer emitted beeps in the sequence of beep-beep-beep, then one beep, then repeated the sequence several times. I could not find anything showing this was some kind of diagnostic code. Any help would be appreciated. Thanks!
Greg
The problem is the control board, seen this happen many times on my service calls, and the new control board always fixes it everytime.
137005000 Control Board
Total price $184 after you return your old one.
Here's the repair manual for your model, it will explain how to access and change it: www.applianceblog.com/manuals/5995413084_Washer_2004.pdf
Glad to help, let us know how it goes.:)
