Furnace high limit switch and fan switch.
s4p1v5
MMHB-070ABHR-06
I had some work done on my furnace, in a house that is new to me, and there was work done before, and now I seem to have an issue that I believe is new. When the furnace decides to kick in (temp on thermometer is not met) it will engage the burner and get hot, it heats for a few minutes, then, just as the high limit switch kicks out the burner, the fan engages, then it drops the heat in the furnace to a lesser level, then the burner engages again(with fan on) and this is when burner and fan operate at the same time, as normal. This whole process must be triggering the high temp switch on the furnace, but I don't know what is wrong.
I replaced:
Transformer
Fan motor
Nordyne 626337 Fan Control Switch F115-30
24V Fun Relay, 90-980 Isolation Relay AC Switch SPST
This is in a Nordyne (Intertherm?) mobile home furnace. As an aside, it does read 70 / 70 on the thermostat when the furnace kicks in. Is there any way to adjust the deadband?
Thank you in advance for your help.
