Gas dryer igniter will not glow / glow sometimes / flame doesn't stay
mochiler
USA
NGD7200
Amana
Need some help on this one...
Igniter didn't glow, i checked all the chain everything seems to Ohm out O.K.
Did the following:
1. Bypassed the relay on the control board - igniter glows.
2. Replaced control board, igniter did glow for a while but flame went out after a few seconds / minutes.
3. Now doesn't glow at all - replaced coils same thing.
4. Went back and bypassed the relay on the (new) control board now igniter glows again.
I am at a lost - can it be another defective control board?! I don't think i hear the relay clicking at start. is there any signal coming from the display part that effects it?
Thank you very very much!
Have you ohm tested the flame sensor?(unplug the dryer first) Should read 0 ohms, take the wires off first.
Here's the flame sensor, it mounts on the side of your gas burner tube:
WP338906 Flame Sensor
If the flame sensor is good, then yes, I'd say you received a defective control board.
Whirlpool WP35001153 Control Board
mochiler
USA
Still no good
Thank you very much Jake!
Following your advice i rechecked the flame sensor and it was actually 1 Ohm, i replaced with a new one and it started working great for about 5-6 loads but now i am back to square one - the igniter doesn't glow.
I did the same test as before (bypassed the relay in the control board by connecting the blue and black wires together directly) and when i do that i get it glowing.
I went and verify the relay "live" and it remains open (infinite resistance) when i start the dryer on time dry.
i have the old control board and the new one - both behave the same and both worked initially when i replaced the flame sensor.
Can there be something bad with the control from the display / control knob?
Is there any schematics of the control board and display board? any other advice - things to check?
Thanks again!
That's very strange, There is nothing else it could be, unless you have a short in your wiring.
You'll need to have Amana come out to see what's going on.
