Goldstripe
- GBD309PVB02
- Whirlpool
- More than 10 years
I have a double wall oven model GBD309PVB02 from Whirpool. After reaching the preset temperature, the upper oven begins to cool down and will not kick the element back on to heat up again, it will cool all the way to nothing if I let it. If I cancel / shut either off and restart, it will heat back up to the preset temp before cooling down again. I did pull the temp sensor out of the upper oven this morning to check resistance at room temperature and it was 1089 ohms which seems in line. The thermostat is likely in the back which would require removing this thing from the cabinet and so I just wanted to throw this out to the experts before I do that. I have confirmed the same behavior on standard bake and convection bake; top oven has convection. anything else i should be checking before pulling it out?
