GBSC0HBXCRBB GE bottom freezer working not the fridge
coline
ontario canada
GBSC0HBXCRBB
Hello I have a ge fridge freezer in the bottom model GBSC0HBXCRBB serial number 318557 the fridge is not cold but freezer is working the fan in freezer seems to have quit . Im trying to figure out if its worth fixing or not any help greatly appreciated
You can check for 120 volts at the freezer evaporator fan motor, if your multimeter says 120 volts while the compressor is running and that fan motor is not running, then its bad.
Here's the freezer evaporator fan motor for your model:
WR60X10282 Motor & Jumper Asm
