GD5RVAXVY02 Whirlpool no water to ice maker
jamesroaden
kentucky
GD5RVAXVY02
Hi I am new to the forum but my ice maker has quit it will not put water in the ice maker I replaced the ice maker and also tried forcing the cycle nothing happened at this point I need Help LOL. when I pushback the paddle for the optics and push back the door light switch the red light stops flashing and goes off.
Do it again, and this time don't press the door switch in, JUST press the paddle for the optics in and see if the LED is STEADY ON.
What position is the ice maker ejector fingers pointing? At you? down in the tray? Straight up?
Normal would be pointing at you or slightly above you.
Here's the ice maker for your model, see how the ejector arm fingers should be pointing right at you?
Ice Maker Assembly 2198597
