GDF510PGD2WW GE DW won't pump out at cycle end but pumps out if started and cancelled.
fyxxer
Kansas City
GDF510PGD2WW
My customer called and said at the end of the cycle the water is not pumped out. If he restarts and cancels it pumps out fine. I asked if he is checking RIGHT after the cycle, not after a period of time, to eliminate a leaking inlet valve. He said RIGHT after the cycle completion.
You will need to check for 120 volts at the drain pump electrical connector when it should be draining.
If 120 volts is NOT present, then the main control board is bad.
WD21X22278 Kit Main Board
