GDF520PGJ0WW Video: GE Dishwasher Grinding Noise
Was it in the drain cycle when you recorded that noise?
If so, then yes, you either have a foreign object in the drain pump, or the drain pump bearing is bad. Before you order a new drain pump, check for a foreign object in it making that noise, like a seed, etc.
Here's the drain pump for your model you can order if needed:
WD35X20553 Pump Drain Kit
dcooney
St Louis
I found some stuff in the sump, most notable was a small wood chip from smoking meat on the grill.
I removed it and ran a test cycle but still had the noise.
Strange thing was I opened the door when the noise returned and seen a blue light, in a circluar pattern for just a split second... almost like something was hot or even arcing.
Definitely going to order the pump now.
Yes, sounds like a bad drain pump.
