GDF570SSJ0SS GE Dishwasher - beeping
MarkJG
Florida
GDF570SSJ0SS
- The dishwasher randomly plays the 3 tone beep that you hear when you open the door. It does this whether the door is open or closed and beeps randomly throughout the day / night. Otherwise it works well, and all lights on the door control panel appear to be working properly.
- I've read other posts about this issue on this model (and others) and have reset the washer with the buttons as well as powering off the circuit breaker. The problem always comes back although powering off the breaker seems to give us about a half-day of normal function, but then the beeping cycle starts again.
- I removed the toe/kick plate etc to look at the main control board STATUS LED.
- Turned the power on, the status light comes on, it beeps 3 times, and goes into the flashing mode.
Is this a bad board? Other? Thanks in advance...
The UI Board is the problem. It was doing this with two other members and the new UI Board fixed them both:
--->Here's the UI(user interface) Board for your model you can order: WD21X23463 Kit Svc Ui Front Logic
"NOTE--->When replacing UI control boards, the new UI Board MUST be configured as per the instructions included with the replacement. If the personality is not set by using the 4 jumpers, the buttons, LED’s or cycles will not function properly".
There is a video of how to replace the UI Board in that thread.
